Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 107
Thread: Getting My 7 Tomorrow!
  1. #21
    Join Date
    Jul 2009
    Location
    Arkansas and . . .
    Default
    The colors on the Mini are stellar. The number on my car is the added total of each month in which my wife, son, daughter and myself were born. ...did I mention the color?
    BTW, it’s great seeing a new build on the forum. Keep us posted.
    Stalker V8, chassis #85
  2. #22
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Great garages guys! My wife has a newer mini but we love them all!
    @pk .... what is the one on the left? Looks like a BMW? Nice collection!
    Tomorrow I'm putting in the engine and trans. I bypassed the headlights and radiator because i know how clumsy I am. I can just see me swatting them with the tail as i set the engine in. LOL!
    I did manage to get the heater/heater core in, the airbox, horns and the headlight supports installed. So far about 13 hours in.
    I'll post some pics of the engine install tomorrow.. cross your fingers!
  3. #23
    Join Date
    Aug 2006
    Location
    Houston, Tx
    Default
    1976 bmw 2002
  4. #24
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Wow...great progress so quickly. You are keen to get out on the roads soon.
    Mike
    1985 Holden Commodore SS Group A
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  5. #25
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Well, I finally got some time to post some pics. A good friend of mine came over to give me a hand with putting the engine in. Unfortunately we lost about 4 hours trying to bleed the air out of a borrowed cherry picker only to run down to the rent a center and renting a known good one.
    We got about 12 hours in it over the two days. Fitting the trans to engine, plumbing up all the hoses, and installing the rad after the engine was in.
    One huge problem we ran into was the engine brackets to motor mounts. I bolted the rubber mounts to the frame and got the engine in close. But the brackets that bolt to the engine were "miles" off!
    This was the drivers (Left) side:
    This was the passenger right side:
    As you can see they weren't even close... very frustrating. The engine needed to be about 3 inches toward the left side and back about three inches. This was impossible as the dipstick was already against the side of the car, the throttle was against the brake/clutch peddle box cover and the intake was against the master brake cylinder!
    I almost gave up and was going to call the dealer figuring that the brackets were the wrong ones. I stumbled on the remedy by loosely bolting the driver side bracket to the rubber mount on the frame and swinging toward the engine. What I discovered was, the engine needed to be tilted, with a list of about 5-10 degrees! I had no idea. When you pick up the engine with the cherry picker and engine tilt it picks it up level. Sure you can tilt the engine with the positioner nose to tail, but the yaw you could do nothing about. Being new to the Caterham, I didn't know that the engine was listing toward the passenger (right) side. So I pushed the tilter towards the passenger side to match the engine bracket and BINGO! I then moved the engine back and everything cleared! My buddy held it there as I bolted the bracket to the engine and then, the right side was spot on!
    Problem solved and time for a BEER!
    We finished plumbing up all the cooling system and called it a weekend!
    A LOT of work but I'm very happy with the result. Its really coming together.
    Next a cleanup of the shop, tool organization, get rid of a bunch of empty boxes and hit 'er again next weekend.
    Stay tuned!
    Apparently I exceeded the number of pics I can post... to be continued
  6. #26
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Here is what I had to move to this post....
    Anyone know what these wires go to. I deduced that the brown ones are a ground. I checked them for continuity... The white and red ones? and the twisted ones with the plastic blades are up in front by the lower rad hose? The FSM has no wiring diagrams what so ever.
    HELPPPPPP!!! LOL
  7. #27
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Apparently something went wrong.... my pics weren't posted. I sort it out and re post
  8. #28
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Great work! It took me and a buddy, 80 hours of total wrench time to assemble my yellow car back in 2000. Funny you should mention engine tilt. My Rover K series motor also cants toward the passenger side. Keep up the good work, you'll be grinning ear to ear soon. Tom
    Mangia bene, Ridi spesso, Ama molto, Guidare veloce
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  9. #29
    Join Date
    Jan 2018
    Location
    Wellsboro, PA
    Default
    Well I got some more done today on the Caterham... oil is in, coolant is in, throttle cable and I fought my ass off with the steering column... those bushings are a nightmare, not to mention the one one the dash board that wasn't even mentioned in the guide. I kept knocking out the nylon inner sleeve. What a pain in the arse.
    They should note that the steering rack should be left loose so you can rotate it as necessary for a better angle to the steering column.
    I found out where those wires go. White and red to the starter and brown to the engine block... I hope. Lol
    Tomorrow the exhaust pipes, then the e-brake and diff... even with the problems I'm still loving the build!
  10. #30
    Join Date
    Nov 2006
    Location
    Higganum, CT
    Default
    Wow, you're making great progress! Very interested in your build because I'm contemplating a new 270S, 310S, or 360S in the very near future. Good luck!
    Bruce
Posting Permissions
  • You may not post replies
  • You may not edit your posts
