Results 1 to 6 of 6
Thread: Modern Caterham Rear Kickup Angle?
  1. #1
    Join Date
    Oct 2008
    Location
    Carlsbad, CA
    Question Modern Caterham Rear Kickup Angle?
    Has anyone seen a specification for (or measured) the angle a modern Caterham rear kickup makes with the ground plane? I'm including a modified version of an image recently posted by Mike in his Brands Hatch thread because it illustrates the question perfectly. In this case it's a Caterham 420R in the photo.
    Thank you,
    Lonnie
Name:	Caterham 420R Kickup Angle.jpg
  2. #2
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Hmmm - never noticed that before. I think it is partly an optical illusion as I am taking the photo looking uphill so the angle is accentuated.
    Here is another Caterham from the same fleet parked on level ground. Does not look as much angle but there is still some.
    Mike
    1985 Holden Commodore Group A (restoration - engine rebuild)
    1982 Ferrari 400i (will repaint to original color in 2020)
  3. #3
    Join Date
    Oct 2008
    Location
    Carlsbad, CA
    Default
    @Croc
    Perhaps only a styling geek like me would care, but it is a feature to some degree in all the Caterhams and many sevenesque clones too. Here are 2 examples of Caterhams. One is from your thread and one is an older Caterham, which is taken from a company publicity photo.
    I think it ads a lot of personality to the rear view. I like the Caterham example (top rail slope/curve too). I'm doing something similar to my Locost based on a 25 degree angle, which is close to the kickup on a New Zealand Leitch 7, but wanted to see how that compared to the modern Caterham setup. If I can get the actual Caterham angle, I'll likely change my design to suit.
    Cheers,
  4. #4
    Join Date
    Apr 2012
    Default
    Quote Originally Posted by Lonnie-S View Post
  5. #5
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    In the last 2 posts all I see is Sgt Schultz
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    1990 Miata
    2013 Mini (Her's)
  6. #6
    Join Date
    Oct 2008
    Location
    Carlsbad, CA
    Default
    I'm not sure what happened there. I posted 2 images, but the links to them show as invalid now. Here is (I hope) a re-post with the images attached.
    @Croc
    Cheers,
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
