Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: BDR oil leaks
  1. #11
    Join Date
    Dec 2014
    Location
    Los Angeles
    Default
    It seems that you guys are approaching this from a purely "BDR" perspective. How does Porsche manage this? Many more seams and seals in an air-cooled motor and most Porsche owners are pretty compulsive about the purity of their garage floor. The same for Ferrari as well. Maybe call the guys at Quicksilver and ask them. I ran an Accusump on a track car for a number of years and used a manual ball valve to shut off the accusump prior to shutdown. It never leaked and I never had to question whether an electrically activated valve was functioning correctly. While it's not exactly the same application, perhaps this approach might work. More positive control than a spring loaded check valve. On the other hand, there are a number of truly essential check-valve controlled functions in aircraft that are very reliable. Maybe check Aircraft Spruce.
  2. #12
    Join Date
    Jul 2018
    Default
    Itís funny, Iím doing the same exact thing today- tracing oil leaks on the left side of my dry sump bdr. I had repaired one already- the oil return sleeve was improperly Ďgluedí and ill fitting to the head. JB weld to the rescue. I see my catch can might be the culprit of some of the other mess, but some fresh oil on the accessory gears.
    BDR 7
  3. #13
    Join Date
    Jul 2018
    Default
    In the two pictures attached, are the oil return valve in the front left if you are facing forward (above the headers). The one picture shows red glue that didn’t hold. The other, the sleeve that no longer fits to the head that I could pull right out. So far the JB weld has solved the issue.
    BDR 7
Posting Permissions
  • You may not post replies
  • You may not edit your posts
