Results 1 to 6 of 6
Thread: Brake pads for track use?
  1. #1
    Join Date
    Feb 2018
    Location
    Montgomery, IL
    Default Brake pads for track use?
    The brakes on my SV (built in 2002) have no identifying marks whatsoever, how can I determine what type of brake pads to replace with? Also, can anyone recommend pads for primarily track use?
  2. #2
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Do you have the uprated 4 piston front calipers? If you do the Mintex 1144 up front and the blue dot sierra pads were the standard road/track set up and work well. I think the Padgid RS14 pads are another option for the front. They are NOT street pads. Tom
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
  3. #3
    Join Date
    Aug 2006
    Location
    Houston, Tx
    Default
    I used Performance Friction Carbon Metallic on my SV. They work well on the track but they do squeal bad on the street.
  4. #4
    Join Date
    Sep 2007
    Location
    Houston, TX
    Default
    Minted 1144 front and rear on the uprated 4 piston fronts, they work great on the street and on the track and no squealing at all. Also be sure to flush the brake fluid and use a high temp fluid.
  5. #5
    Join Date
    Feb 2018
    Location
    Montgomery, IL
    Default
    Thanks for the tips everyone ... I do not have the 4 Pot calipers ... But I have already flushed brakes with high temp brake fluid
  6. #6
    Join Date
    Aug 2006
    Location
    Houston, Tx
    Default
    I have the 2 pot brake on the Zetec and the AP 4 pot brake
    on the R300 and SVT. Honestly I cannot tell much of a difference between them.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
