Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: 1978 Caterham with Checkered Past
  1. #31
    Join Date
    Aug 2006
    Location
    Virginia, USA
    Default Paint is for Wimps
    Quote Originally Posted by xcarguy View Post
    Raw, naked, bare aluminum...car porn!
    I need to get a T-shirt with Paint is for Wimps and a picture of a 7
    Dean G.
  2. #32
    Join Date
    Mar 2015
    Location
    Massachusetts
    Default
    Tried to go for a drive today but about 10 minutes in the engine stopped. For some reason I had low to no fuel pressure but was able to limp it home. Disassembled the fuel filter and found a mess inside, no idea what it is, kind of looks like peeled paint.
  3. #33
    Join Date
    Jul 2013
    Default
    Let that be a lesson to all of us. Never put latex house paint in the gas tank.
    Seriously, thank God for the filter. It looks like it did its job. Might want to scope the tank and/or run a couple tanks of fuel system cleaner.
  4. #34
    Join Date
    Jun 2007
    Default
    Maybe it is coating used to seal rusty tanks, if so it might be time for a new tank.
    2006 Caterham 7 SVT(sold)
  5. #35
    Join Date
    Mar 2015
    Location
    Massachusetts
    Default
    Quote Originally Posted by breezy7 View Post
    That's what I was thinking, will have to check it out.
  6. #36
    Join Date
    Oct 2014
    Location
    Florida
    Default
    I bet someone used a product called Kreem which is used to seal motorcycle/atv etc. gas tanks from rust, corrosion and leaking. It is a lousy product with a checkered history. I suspect that may be your culprit? With the possibility of a total tank failure, might be cheaper and less frightful to get a new gas tank?
  7. #37
    Join Date
    Apr 2015
    Location
    philadelphiaish
    Default
    i'd say it's definitely new fuel tank time.
    my car had a fuel cell in it at one point and i was pulling foam out of my fuel filter until quite recently.
    '87 Caterham Cosworth BDR 1700 "HPC Spec"
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
