Results 1 to 7 of 7
Thread: alternator?
  1. #1
    Join Date
    Sep 2017
    Location
    Kernersville NC
    Default alternator?
    Good morning, New to the 7 family. I purchase a 1996 Caterham with the 1600 Ford crossflow engine in July. Im in the need
    of an alternator. It has a Valeo but all of the numbers don't cross to anything. Im hoping someone can help. Thanks
  2. #2
    Join Date
    Dec 2012
    Location
    Gold Country Region, Northern California
    Default
    I would like to follow this thread, I could use one too
  3. #3
    Join Date
    Jul 2009
    Location
    Arkansas...and Indy
    Default
    FWIW, a few of us on the forum (some Storker owners, in particular...and maybe others of different makes) are using the light weight Denso 55 amp alternator pirated from something such as a 1997 Geo Prism. Going forward, it may be an alternative; easy to source.
    And here is a good video link to a Denso install: https://www.youtube.com/watch?v=U7Zv...ndex=2&t=1064s
Name:	alternator and belt mount (2).jpg
Name:	alternator and belt mount (1).jpg
    xcarguy
    Rise of the 'Super Chicken'...a Somewhat 'Suave' Story
    http://www471.pair.com/stalkerv/gall...g2_itemId=5938
    Live life with passion; history has proven there’s no getting out of it alive.
  4. #4
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
    Default
    Addendum to the suave stork message
    If you're looking for a direct replacement: I discovered my car was originally supplied with a NipponDenso forklift alternator.
    It worked well but no one could identify it because their searches were only automotive.
  5. #5
    Join Date
    Nov 2010
    Location
    New Jersey
    Default
    This is the direct fit alternator. I am not aware of a US supplier although not too expensive even with shipping. Burton ship same day and generally delivered within a week.
    http://www.burtonpower.com/lucas-acr...g-acr60rh.html
    1985 Caterham Super Seven
  6. #6
    Join Date
    Oct 2006
    Location
    South Lyon Michigan
    Default
    Another small and lite Wt option would be the 40 Amp Denso that is fitted to a Daihatsu and Suzuki bandit.
    P/N A073, also Tractor Spares Co. P/N 196300. but you would probably have to change the pulley, I'm assuming you have a "V" belt. Dave W
  7. #7
    Join Date
    Feb 2012
    Location
    Roswell GA
    Default
    I took alternator to a rebuilder and he had a direct replacement. He said it was a common part to other Lotus models. I'll look to see if I can find some more helpful info.
    Life happens while you're making other plans
    1995 Caterham Crossflow RHD
    2013 Mini (Her's)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
