Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bootstrap.php(430) : eval()'d code on line 143
Garage Floor Finishes?
Results 1 to 7 of 7
Thread: Garage Floor Finishes?
  1. #1
    Join Date
    May 2010
    Location
    Chicago
    Default Garage Floor Finishes?
    The new house we moving into has a 13" drop in the garage floor! My only requirement before buying the house was "we must fix the garage floor", well next Monday the old floor gets jack hammered out and a new level floor installed. So I am planning on taking the opportunity to get the floor coated with something. So what is everyone's experiences. I like the finish Mike has in his NJMP garage.
    Graham
  2. #2
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
  3. #3
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Hi Graham
    You may not want to click that link as it is pricey. But thats ok as Jay can afford it. He just bought his wife a new kitchen.
    My floor came from Terry Kenny (father to TJ that many people met at NJMP in July). At the time he was running this business
    https://garagestoragesouthjersey.com/garage-flooring
    The floor is great. Easy to clean up. Very durable except when a 65 Mustang on jack stand rollers decides to lock a rolling wheel (scrape....)
    My mistake was to get a uniform light color. It shows the dirt like nothing else. Oil from the aforementioned 65 Mustang, 2008 orange Caterhams, 2004 maroon zetecs, Locosts with Hand engines, etc tends to stain the floor and vigorous use of thinners is required to clean. I should have chosen one of the darker variegated finishes. I now use a Hoover wash and vac cleaner with cleaning fluid and thinners in it to clean things up - works well. Interim cleaning is covered my my two trusty roombas!
    Mike
    1975 BMW CSL Group 4 (restoration - awaiting new engine)
    1985 Holden Commodore Group A (restoration - awaiting engine rebuild)
    1982 Ferrari 400i (catching up on deferred maintenance)
    1992 Ford Escort RS Cosworth
    1991 Range Rover
  4. #4
    Join Date
    May 2010
    Location
    Chicago
    Default
    Talking to a couple of local shops you have to wait for the concrete to cure for 60-90 days, I did not know that not it makes sense. So it looks like the new floor will be a spring project.
    I did like the Big Ass lights
    Thanks everyone
    Graham.
  5. #5
    Join Date
    Jan 2007
    Location
    Shawnee, Ks
    Default
    When they put the floor in make sure it is strong enough to put a nice two post floor lift in!!!!!!
  6. #6
    Join Date
    May 2010
    Location
    Chicago
    Default
    Yep, already talked to the concrete guys about that.
  7. #7
    Join Date
    May 2016
    Location
    Houston, TX
    Default
    Before moving into our current house, I had the garage floor coated with epoxy using kits from Home Depot. At the time, the kits were about $120 each. We used 3 kits for a 2-car garage that has a "step" at the back wall. We are the first occupants but the guy applying it cleaned the floor with (muriatic?) acid anyway, just in case the builders left something on it. It has held up well over the last 6 years. It doesn't hold dust like the usual concrete floors.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
