Results 1 to 6 of 6
Thread: S2K headlight wiring
  1. #1
    Join Date
    Nov 2009
    Location
    Austin, TX
    Default S2K headlight wiring
    I am using S2K engine and wiring harness but am not using the S2K headlights. trying to connect standard Hi/Lo connection to wiring harness. Looking at schematics, the S2K harness relies on their headlight DRL module to activate hi beams. Has anyone made this work on their car? The current plug in will activate low beams only.
    This is car
  2. #2
    Join Date
    Jan 2006
    Location
    St.Louis, MO
    Default
    Sorry, I wired the headlights directly to a HI/LO switch on the dash, didn't use the harness.
    Jerry
    WCM Ultralite S2K (Sold 8/17)
  3. #3
    Join Date
    Jul 2007
    Location
    Bakersfield, Ca
    Default
    Yeah, independent of harness on mine.
    "HECK IS WHERE PEOPLE GO WHO DON'T BELIEVE IN GOSH"
    2008 Ultralite S2K
    2016 Mazda CX-5
    2008 Volvo C30
    2005 Mini Cooper
    1999 Miata
    1967 Chevy C10
  4. #4
    Join Date
    Nov 2009
    Location
    Austin, TX
    Default
    Discovered part of the issue was the car and part of harness was from Canada, which requires Daylight Running lights. Hi beams were putting out 6 volts to hi beams to turn them on when driving. Finally just added a new relay and activated from the high beam switch on column.
  5. #5
    Join Date
    Aug 2016
    Default
    Quote Originally Posted by lambobuilder View Post
    This is car
    Sorry, not a helpful post here, but I'm super curious...
    Are... are those.... are those Chevy pickup taillamps?
    - 1300lbs, 170hp. British.
    - 2350lbs, 630hp. British.
    - 2900lbs, 140hp. Japanese.
    - 3500lbs, 280hp. Italian.
  6. #6
    Join Date
    Nov 2009
    Location
    Austin, TX
    Default
    I believe a Tahoe if I remember correctly.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
