Results 1 to 8 of 8
Thread: 2004 Brunton Classic StalkerV6 SuperStalker Supercharged 3800 With Trailer
  1. #1
    Join Date
    Oct 2006
    Location
    Plymouth, MN
    Default 2004 Brunton Classic StalkerV6 SuperStalker Supercharged 3800 With Trailer
    This is Classic SuperStalker Chassis #20
    Car built in 2004 and titled in the State of Minnesota
    Trailer built in 2006 and also titled in Minnesota
    $20,000 for car and trailer together.
    Engine is a supercharged 3800 from a Pontiac Grand Prix GTP
    Transmission is WorldClass T5
    Differential is 3:42 with GM Torsen
    Car is very quick and very fun.
    Has been driven at autocross a couple times but has never seen track use.
    Comes with a set of 13" racing slicks on steel wheels only used once for autocross.
    Comes with a custom built drive-on tilting trailer, The trailer no longer has the tool box on the front, it was getting in the way so was removed. I'll post more recent pics of the trailer (without the toolbox) soon.
    Featues:
    * Quick Steering Upgrade to newer factory configuration
    * Cycle wing stays Upgraded to newer stronger style
    * Upgraded from original 3.4 engine to 3800 Supercharged
    * Rear brakes are Buick Grand national Aluminum drums.
    * Have factory disk brake mounting brackets (not installed)
    * Front brakes upgraded to Wilwood Aluminum Calipers
    This excellent car has provided my wife and I many years of great fun at various 7s gatherings and trips exploring the countryside. We are sad to see the car go but we will be downsizing the house and will no longer have reasonable storage options.
    Thanks!
    Drive safe, Have fun!
    StalkerV6 #20
  2. #2
    Join Date
    Jul 2013
    Default
    Awesome trailer. If I ever grow up, I want one1
  3. #3
    Join Date
    Oct 2006
    Location
    Plymouth, MN
    Default
    Thanks!
    It works extremely well.
    StalkerV6 #20
  4. #4
    Join Date
    Jun 2017
    Default
    Still available? How much does the trailer/car combo weigh?
  5. #5
    Join Date
    Oct 2006
    Location
    Plymouth, MN
    Default
    Hi Sorry, life got very busy and I didn't check the page.
    I have not weighed them. Back-of-the-napkin guess 1500 Lbs for car, 800 Lbs for trailer, maybe 2300 Lbs for both together. I can try to get a more accurate weight this weekend.
    Thanks!
    StalkerV6 #20
  6. #6
    Join Date
    Oct 2012
    Default
    Quote Originally Posted by xromad View Post
    Thanks!
    This seems like a really good deal for someone. If you have space for the trailer it sure seems ideal.
    Nice color scheme on the car also!
    Good luck with the sale.
    BT
  7. #7
    Join Date
    Sep 2008
    Location
    Michigan
    Default
    I pm'd you,I wanted to make sure you received it. Thanks Rich
  8. #8
    Join Date
    May 2016
    Location
    northern CA
    Default
    PM sent
Posting Permissions
  • You may not post replies
  • You may not edit your posts
