Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 66
Thread: Santa Came early - R400 Roller Barrel Conversion!
  1. #41
    Join Date
    Jan 2014
    Location
    Stamford, Connecticut
    Default
    Alright! I finally received the ECU back from the UK, completed a few checks, and finally took her for a spin today. OMG.. felt strong, perhaps more torque than previously but probably the biggest difference is the sound! unreal.. roller barrels with cat bypass changed the RPM tune completely. Pretty decent and "civil" at 3000 RPM but past 5000 RPM, it is a screamer. Plus lots of backfire when I let go of the pedal rapidly. My only concern right now is if i'll be allowed at LimeRock ( able to meet the decibels rules?). I have the r500 carbon fiber airbox which helps... but i guess we will see.
    Next will be to dyno the car to see what this upgrade really did. Will keep you posted.
  2. #42
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    I think intake/exhaust sound is at least as important as hp! My old X-flow had a much better sound than the current Zetec does and was much more satisfying to run up and down the gears. It was also had your engine's off-throttle back fire. It sounded ferocious (but its bark was worse then its bite). I will also be interested in the dyno results. Do you have pre-mod #'s?
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
  3. #43
    Join Date
    Jan 2014
    Location
    Default
    What a great day on the east coast. Could not resist to take the car out for a spin. Overall, i like the new engine setup, but it feels like it lost a bit of low end torque (under 3000 rpm) or not as responsive off the line .. but then it corrects the the car feels solid and stringer especially above 4500 rpm. I still plan to dyno the car soon, but has anyone experienced a change in torque (lower?) under 3000 rpm when changing to roller barrels, especially when opening the rollers suddenly? just curious..
    thanks!
  4. #44
    Join Date
    Mar 2014
    Location
    Gibbsboro NJ
    Default
    Quote Originally Posted by SK400 View Post
    thanks!
    Hi Seb, for some reason I'm only just catching up on this thread. Conversion looks great, nice job. Funny when Caterham flashed my ecu from R300 to R400 spec, when I built the car, they made the same mistake on the 4:1 rpm read out. Obviously slow learners. Can't wait to see you on track this year and relieved I now have an excuse
    Sent from my iPhone using Tapatalk
  5. #45
    Join Date
    Jan 2014
    Location
    Default
    Simon, good to hear from you. Let's see if this upgrade really helps with lap times.. I suspect that it will still be really difficult to follow you and keep up with your pace!!
    On a separate note, I have a dyno test and tune appointment on May 6. I unfortunately don't have the pre-readings but still curious to see what the engine puts out with the roller barrels. I'll test with and without the R500 carbon airbox.
  6. #46
    Join Date
    Feb 2009
    Location
    The Frozen Northeast
    Default
    seb - who are you using for tuning?
  7. #47
    Join Date
    Jan 2014
    Location
    Default
    P1 Motorsports in Stamford, CT. A good shop. Candidly, I wont be tuning much on the dyno simply because my ECU is locked by Caterham. But they also have great alignment equipment, scales etc and last time I went in for suspension and alignment tuning, the owner did all the work himself on my car.
  8. #48
    Join Date
    Jan 2014
    Location
    Default
    Slight correction - P1 Motorcars
  9. #49
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    Can't Caterham tune long distance on the dyno? I thought that's what Tom (YellowSS) did?
  10. #50
    Join Date
    Sep 2006
    Location
    Southeastern Pa.
    Default
    Mike, you are almost correct. It wasn't Caterham who did the remote tuning, it was SBD an engine turner in the UK. My ECU is the MBE unit like Seb's but mine is not locked so it can be accessed and the map can be modified without having to send it back to Caterham. Tom
    2000 Caterham Superlight #123
    1.8L VHPD Rover K Series
    2009 Caterham SV
    2.3L Cosworth Duratec
Posting Permissions
  • You may not post replies
  • You may not edit your posts
