Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Tire choice
  1. #11
    Join Date
    Oct 2016
    Default
    I've fitted Federal 595 RS-R's on the back. They are working well, supposed to be similar to R888 (although I have never personally used R888's) but only half the price. Feel quite soft to the fingernail and give a lot of traction when the road's not too cold. When it's cold out and damp/greasy they aren't too great but then I don't think you'll find any tyre to work with a very light weight high power rear wheel drive car in the cold!
    All I can say is avoid tyres designed for regular sporty cars as the rubber is way too hard for very light cars (to get decent life when fitted to a car two to three times the weight!)
    Tom.
  2. #12
    Join Date
    Mar 2011
    Location
    Melbourne, Floirda
    Default
    Quote Originally Posted by FE07 View Post
    Michael,
    Hoosier was a family run business and I understand it was sold when the younger members of the family didn't want to take it over. According to the scuttlebutt on some SCCA related boards, shouldn't be too much of a change but no one knows for sure.
    They certainly make great race tires and have always had great trackside support. Would suck to have them go all 'corporate'.
    Jim
    Well they still make a good tire but the prices have gone up a good bit. I used to pay $215 for a 20.00x9.00-13 R35 compound (bias ply), now they're $255 each. However, even with the price increase, it is hard to beat the performance. IMHO, Toyos are good but nowhere near the stickyness.
    2004 Caterham R300
    2015 Corvette Z06
    2015 Ford F-150
    2015 Chevy Tahoe LTZ
    1969 Corvette Big Block
    1967 Pontiac GTO
    1964 Corvair Spyder
    1964 Corvair Greenbrier
    1965 Corvair Corsa 140 HP
    1966 Corvair Corsa Turbo
    2015 Porsche Panamera S
    2005 FFR Cobra
    all still in the garage
  3. #13
    Join Date
    Dec 2017
    Default
    Bumping this thread. I just bought a set of 13x6 Panasports to change my "93 16" 205/45x16 out. Primarily street use. Suggestions on 185/70x13 tires, Kuhmo or Vredestein available or 205/60x13 Goodrich or Vredestein available at Tire Rack. Other vendors to check or size suggestions?
    Thanks!
  4. #14
    Join Date
    Apr 2008
    Location
    San Jose, CA
    Default
    Quote Originally Posted by Lotusfan View Post
    Thanks!
    Try Pirelli CN36 in 185/70r13. I've been really happy with them on my bmw 2002 and they have a great retro tread pattern. performanceplustire.com has free shipping.
    Other options are Toyo R888R, but may not be the best for street driving - especially if you encounter rain often.
  5. #15
    Join Date
    Dec 2017
    Default
    Thanks for the reply and suggestion which I'll keep for my vintage rides, but for my Caterham I'm more interested in handling and the feel. Thoughts on 185/70 v. 205/60 or should I go 185/60 and then just change the ride height? I think the gear ratios as they are are about right so I was inclined to keep the same rolling diameter.
    Thanks
  6. #16
    Join Date
    Feb 2009
    Location
    NYC
    Default
    Caterham standard fitment in the 13s are Avon ZZS - good tires in a performance setting but can handle the rain too.
    185/55 and 215/55 options. The 215/55 is too big for your panasport rims. However, the 185/55 probably shrinks your rolling diameter too much?
    While I have not driven on the tires you suggested, the 205/60 would be my size choice based on performance expectations.
    Mike
    1985 Holden Commodore SS Group A
    1985 Holden Commodore Group A
    1982 Ferrari 400i
  7. #17
    Join Date
    Apr 2008
    Location
    San Jose, CA
    Default
    205 is a bit wide on a 6" wheel. 185 is perfect. Pirelli CN36 are a modern soft compound; I think you'd like the handling and feel, but the sidewall is a bit tall at a 70 aspect ratio (although close to your original 16" spec). Avons are nice, but quite expensive. I'd vote for the Toyo R888R in 185/60, if you can live with the change in diameter.
  8. #18
    Join Date
    Dec 2017
    Default
    Quote Originally Posted by TheDingo8MyBaby View Post
    While I don’t intentionally go out in the rain, where I live rain is unavoidable. How bad are those Toyo’s in the wet? Also, 6” is within the recommended specs for 205 tires, is there really that much of a downside to that combination?
    thanks again for the replies!
  9. #19
    Join Date
    Oct 2006
    Location
    Cincinnati
    Default
    Tire Rack doesn't recommend Toyo R888R's for standing water. My Toyo R888's were ok on moist roads, not in downpours. They were really the worst of both worlds, a so-so track tire and a so-so rain tire. I think the R888R is supposed to have fixed the track day problem, but not the rain issues.
    Kitcat:AKA, Sir Spinsalot
    '97 Caterham Super Sprint, 1700 Crossflow-sold
    '09 Birkin S3, Duratec-sold
    '03 Caterham Zetec track car
    '19 Honda Civic, Type-R
  10. #20
    Join Date
    Jan 2006
    Location
    Seattle-ish
    Default
    Toyo states that 6" is the preferred wheel width for the 205/60-13 R888 and RA1. I checked with them before buying my wheels back in 2012 and they confirmed this recommendation. Given they do recommend wider wheels for 205/50 and wider still for 205/45, there is likely something about the 60 profile that works better with the narrower rim.
    Having run both tires, I prefer the RA1 to the R888 for road use. The RA1 has a 10% softer sidewall -- better for a very light car like a se7en -- and I found it more forgiving when pushed. That's not to say the R888 isn't a forgiving tire, but on my car the RA1 feels more playful in the corners, and hence, more fun. I can't comment on lap times differences since my car is used exclusively on the street and back roads. I also don't have experience with either tire in standing water, but it's probably worth a call to Toyo to ask. They've always been very helpful to me in the past and likely have a quantitative view on this aspect of the tires.
    '68 Lotus Elan FHC
    '95 Porsche 993 C2
    Throttle Steer
Posting Permissions
  • You may not post replies
  • You may not edit your posts
